I fixed mine about a month back - annoying little job but worth it imho.
When you pop the horn push off there should be a tin disk with a spade connector for your live (?) wire to run to. This will be held on by three screws, each of which will pass through a plastic bush (the bush is horseshoe shaped and all three of them pass through it) underneath which are springs - one per screw.
To clarify, from top down it goes screw into tin ring into plastic bush into spring into horn. Clear as muck, no? :lol:
I ran a new wire by unbolting the steering column from the rubber between it and the steering box. This will be endlessly easier with a second pair of hands as you can't be in and under the bus at the same time
Unbolting this rubber from the steering box means you can take it out (check for wear and replace if necessary). Now pull your new wire through using your old one and run a bunch of excess under the bus (nothing worse than finding out it is too short!).
I then ran this wire through the middle hole of the steering bush and brought it out passed the bolts that go on the steering column side. Bolted the lot back up together and cut the wire to it's correct length after running it through the chassis leg to the horn mount. Spade plug both ends and then, pow, job's a good'un.
Thoroughly confused? Me too! PM me for my mobile number if you want a talk through any of it when you're there looking at it
