bananacustard
Just bought an accuspark unit for my 009 dissy and have encountered 2 problems fitting it. The first I sorted i.e. where the leads exit there's a round hole and the rubber bung in the accuspark unit is square. Luckily the rubber is very soft and I managed to squeeze it in anyway.
The second problem is they supply a black plastic collar (trigger ring) which is supposed to slide down over the distributor shaft. Pushing this down as far as it will go leaves no room for the rotor arm to sit fully in place.
What should I do? What have other folks done?
cheers, Jeremy
cheers, Jeremy
