Nick-Rackham
I've got two paint removal / preperation questions that I need advice with.
I'm slowly getting all the old underseal and crap off the chassis and underneath. It's a combination of underseal over hammerite over either original paint or previous underseal!
Once it's cleaned off as far as I can with scraping etc I'm thinking of treating where it's surface rust with a wire brush, metal ready, wash off, dry thoroughly and acid etch then red oxide. Trouble is, there's a lot of the old underseal "spread" in places that no amount of scraping will remove, just moves it around like treacle! So I need to know what's the best way of getting this off. Once it's off what's the best way to prep for acid etch? quick rub down to give a key? wipe with thinners to clean? I'm kinda stuck with this as to what is best to do! I want to do it properly so it lasts and I don't have to strip it all and go again! I've already got metal ready, acid etch, red oxide, stonechip and waxoil and was hoping that would treat it, seal it, protect it and ...... (hopefully last!) Open to all suggestions ideas etc
The next thing I'm thinking about is how to remove the many resprays she's had!
I've got a really thick Neptune blue over beige/yellow primer, over red oxide, over metallic blue over white primer and then the original paint. So what's the best and quickest / safest way to get back to the original paint?
Many thanks in advance for all help advice and guidance
