radish said:I would disagree Johnny, I have Gabriel shocks front and back and it's lovely. It can cost you a £1000 but mine cost nothing as I bought multiples of everything and sold it on as a kit and pairs of shocks.
I have viair comp , paddle switches and gauges. All the fittings are cheap online. You could use valves and switches but this will cost more.
It is a comfy doesn't bang at all nothing like just lowering alone, i can run between 40-60psi bu5 around town or towing i can jump it up to 160psi, max is 190psi. I can get about 10mm lift at the rear and the front is about 6-8cm with some lift arm extensions I've made.
Johnny is right though if you go to matt balls or evil Ben it'll cost, but it will be a different set up and great work.
It really depends how low you want to go which could determine how much lift you need, then you may have to have bags.
the weight of the camper version of the VW Bay Window Bus weighs in at 3200 lbs
*Sam* said:You retain the torsion bars and leafs, I have covered thousands of miles on the hijackers as has Darius and mycha.
Your not being arse, your quoting the figures you have read on the spec ?
It's a bit like low profile tyres I guess, a bus is way past there advised limit but people use them and don't seem to have an issue.
Johnny said:ah well....thats a completely different kettle of fish. i thought we were talking about air ride, as in no torsions....
Graham L said:Just dont see the need to go to the expense unless you want to drop it to the floor when you turn up on site rather than a static slam, each to their own but I've never seen the attraction and if you were going that route you may as well go for the hydraulic set up, seen too many air system not work very well on buses as there are so many variables.
You could always consider a French Slammer set up and we run 2 buses that you can come for a ride in before committing, dont think theres anyone else out there offering that at the moment
And you can get reasonably low without notching or tubbing. below is a customer bus we recently did
