*Sam* said:I also have the Gabriel's 49230 is the model number from memory.
I'm not sure how much more lift you will get without fitting lift arms, plus you could go another 20PSI as Gabriel's are 200PSI shocks.
I currently have lift arms fitted and the beam set quite low, I get 11cm of lift at 200PSI, with 40PSI in the shocks the bus is sat on the wheel arch tubs.
Hope this helps
Maybe I'm not fully awake yet, or something lost in translation, but..... what is referenced when naming "lift arms" (anyone)?
