- Joined
- Oct 26, 2010
- Messages
- 3,247
- Reaction score
- 17
- Location
- Leeds
- Year of Your Van(s)
- 1971
- Van Type
- Panel
So it turns out that my mechanical fuel pump needs replacing as one of the brass barbs came off with the pipe and I'm not taking any chances with a repair.
So a friend of mine suggested an electronic fuel pump. So I've spent a couple of hours researching stuff but I still have questions.
I have twin Solex 32 PDSIT-3's (I think).
What pressure should be provided to these?
I've uncovered lots of options and want to get some opinions.
Pump
1) Huco. Comes in both a push (near tank) and a pull (in engine bay). Any preferences?
2) Weber low pressure pump
3) CB Rotary pump. Mixed reviews. Lots of people reckon it's the dogs danglies but a few people have had them fail a bit too quick.
4) One of those "bog standard" facet ones (I think EMPI do them, among others)?
Blockoff: lots of choices. Is there really any difference?
Regulator
1) Filter king regulator. Looks like a good piece of kit and gets good reviews. Is it overkill?
2) SSP jobby...
3) Cheap chromey ones. Cheap and cheerful or problem waiting to happen?
Fuel Lines
It looks like 5.6mm is the ideal size. However I've noticed a couple of suppliers offering 5mm ID. Will this be too tight over the 6mm connections?
The hard line that goes through the firewall: I assume copper/ cunifer pipe will be alright?
Other option: widen the hole so that I don't need a hard line. Still shove a bigger grommet in the hole and probably put some cable conduit around the fuel line at that point for added security. Less joins sound good to me. What do you think?
I think that's all the questions that my brain has been able to hold on to.
All and any advice appreciated!
Cheers,
George
Pump
Regulator
2) SSP jobby...
Fuel Lines
Cheers,
George
