update time
The break down bus broke again on the saturday of volksworld show as i tried to get off my drive, the steering idler box ripped off again. Not down to dodgy welding but probably the heat from the welds has weaked he metal so it just sheared off!! This has nothing to do with a late bay box conversion which worked graet.
So i decided to go for power steering instead of making a box for the steering idler pin, what a stupid idea that was . I have had a great deal of time to work on it so i have had a few hours over the alst few weeks to try and make it work.
List of parts:
T25 bevel box saxo steering pump astra mk3 power rack
1302 steering coupling uni joint
corsa double uni joint
I machined the 20mm rods at work Free
20mm rod eye bearings a
few pieces of flat bar for supports Free
Hydraulic hose Free
Stainless nuts & bolts
track rod arm are a astra with a new M14 thread so T2 track rod ends can be used.
I have it all tacked in place now with wheels turning, the arms need modded a little then i can pull it apart and weld up everything. I may underseal it as i have 5ltr or i could spend even more time under there cleaning the crap off and stone chip it instead.
I will update when it is finished.
Oh yes i forgot to mention i took inspiration from Mycha to build this, thanks by the way. One problem is i run K&L Mycha has BJ, the tubes on a ball joint beam are further apart so when i looked at pictures and used them for referance some things just don't fit in the same place.
Also if you have a beam narrower than 60mm it probably won't work.
Cheers Darius
