Passion 4
Fantastic monitor in great condition - £150!
This Apple 20" LCD Cinema Display monitor is perfect for the prosumer and professional alike. Imagine multi-tasking with multiple full-size windows open simultaneously, or editing video with a super-wide timeline! It has a native resolution of 1680x1050, and a contrast ratio 400:1, for stunning quality on either a Mac or a PC. Brightness - 300 cd/m2 Viewing Angle - 170 degrees horizontal / 170 degrees vertical Antiglare Hardcoat Screen Treatment Kensington Security Port User Controls - Display Power, System Sleep, System Wake, Brightness and Display Tilt Connects to a PC or Macintosh via a digital DVI connection
Eliminate Tunnel Vision. The widescreen design of the Apple Cinema Display line offers a natural format for arranging documents the way your brain processes them—longer wide than high. That's why each display gives you the best view for your work. It just makes sense to be able to display a Web page and its code next to each other horizontally, or long video timelines in wide format. Apple engineers find that the nearly 100-pixel per inch resolution is ideal for images, yet allows you to easily work with sophisticated type treatments or just plain email. This painstaking attention to detail moves the industry forward and gives you best LCD technology available.
Connect with Pure Digital DVI. Give your laptop a second display when you're not on the road. Connect directly to any laptop with a DVI port. The DVI connection removes all barriers to using an Apple display with a PC, if your graphics card supports DVI with DDC technology for widescreen viewing.
Effortless Adjustment. The smooth motion hinge on your Apple display requires very little pressure to tilt the monitor to a different position. This design allows you to you view the display at whatever angle works for your environment, anywhere from -5° to 25°.
Pure Signal. When you need to manipulate color in any media, image distortion is simply not an option. Analog conversion problems caused by a VGA connection become progressively worse as you move to monitors that have higher resolutions or longer monitor cables. These issues fade away with an all digital signal. DVI transmits a distortion-free digital signal from a digital location in the graphics card to a digital location on the display’s screen. This digital connection gives you the full clarity and stability of liquid crystal technology — with sharp, clear pixels from edge to edge.
Responsive Feedback. Pixel response time provides a good measure of a display’s performance in media critical applications, such as video, 3D and motion graphics, or even when you’re taking a break with a game. An Apple display provides fast pixel response time across the entire spectrum from black and white, to every shade of gray.
Peripheral Devices on Your Desktop. This display includes a FireWire 400 hub and a USB 2.0 hub, each with two ports. So you can connect a printer or scanner, or a digital camera or camcorder. The FireWire port provides a convenient place to plug in an iSight camera for video chat, presented beautifully on your Apple display, or to connect your iPod dock. You can also make best use of all the latest USB 2.0 devices, whether you're using your display with a Mac or PC.
Features;
1,680 x 1,050 optimal resolution, 16.7 million colors
400:1 contrast ratio, 0.258 mm dot pitch
16 ms response time
DVI, Firewire and USB 2.0 connections
Features;
16 ms response time
