Hi - starting to clear out the garage ...
Note - same add is going to be posted across Early Bay, VZI and SSVC so I will try and sell to the person who responded
first on whichever site.
All can be collected from Halifax with some knocked off posted price
Paul
07771 506383
Split Cargo floor repair panel which fits under the cargo doors on LHD vans but can be used on RHD with mods - brand new VW
Heritage Red HD item - currently out of stock at £84 on Heritage web site - SOLD
Pair of OG splitscreen headlamp rims - drain holes at the bottom - chrome is a 7/10 on left and 8/10 on right - right one
has had a dent hammered out quite neatly other than that solid as expected - £20 posted
Cab overhead airbox cover - hole cut in middle, otherwise good - £20 posted
Twin port front and rear engine tinware - good no rust but rear section has had a couple of holes very neatly welded up -
£20 the pair posted
3 x tinware bits which cover the pulley nut - only fitted for a short while on vdubs - note one is a different shape - £10
each posted
Bay window blower fan for heating - tested across 12v and appears ok and free - came form a 72 cross over - SOLD
Bay window heating pipes from the back of the engine - came from a 72 cross over Bay - pancake engine - looks like they are
through tinware bits - £15 posted.
Some Hen's Teeth -pair of early bay over gearbox tinware items both very good condition, no rot - these are single port but
the red one has been marked in pen where it could be cut out for twin port air feed - £50 each posted RED ONE SOLD
12 v dynamo removed from my 69 Bay due to alternator conversion - £10 collected
2 ring cooker plus grill - very clean - I rubbed it back and re-enamelled it in white - works nicely although the chrome grill rests on top of the burners so I think either burners are wrong or just needs bit of ingenious thinking to raise it 3 or 4 mil. There I a fold down glass lid which comes with it which I will post but will not take any liability for if it is damaged in transit - £40 posted
Dimensions are 39 cm by 39 cm - plus 8 cm below mounting surface and 3 cm above
Paul
07771 506383
£20 the pair posted
each posted
