Bay breather tanks
dubbus56
Jul 24, 2008
11
We have had a quantity of breather tanks made which are specifically for bay windows.
We know they work because we have them fitted in our vans now.
They are made exclusively for us out of Aluminium.
They have swaged push on fittings on each end and a drain underneath to take the oil back to the case. The breather caps themselves are spec'd for racing Aston Martins.
The inlets go into a tube that runs the width of the tank and is perforated on one side to allow the mist to seperate and the oil to run back down.
The inlets allow you to run a breather from each rocker cover and one from the case, the drain connects back to the case.
We can supply the tank alone. £99 plus P&P plus vat.
The tank and a pair of rocker covers with the breather attachment on. £160 plus P&P plus vat.
The fuel pump blank and whatever other parts you need to complete the job on your vehicle can also be supplied.
If you are running a stock fuel pump, we can supply the tank with fewer inlets.
There is also an option of having screw on fittings.
The tank mounts to the roof of the engine bay.
Full instructions included with every purchase.
Tank
Internally baffled pipework running through
Any questions or to place an order, give us a call on 01684 298 700
