I'm getting dropped spindles so I've got to raise my beam back to stock height and then adjust down. Only thing is the top adjuster is currently I tiny bit clear of the gea shift rod. If I move it it will foul. I think I've heard this coming up as an issue before? Is the solution just to mark up the gear shift where it fouls, cut a section from the top and weld back in a. flat piece? Or is there something I'm missing?
It's a 70bay with the 2 serated plates as adjusters
