It's been so long since updating, had a great summer and Bert has done us proud, only issue was losing gears on our way to and back from busfest, after dropping the engine it turned out the gland but on the flywheel had the rollers collapse, new one put back and sorted
Now the van is parked a few upgrades are in order, first job though is to get rid of the nasty vibration noises that is deafening at 50-55 mph, suspecting it coming from the roof, so taken off the lining and pretty sure this should be welded.
Not sure if this was an adventure wagon thing or if previous owner has done something, either way welding set if coming out!
So, welding went good, vibration gone and didn't manage to burn anything, result me thinks.
Been tinkering with truck mirrors as missus liked them, so managed to fit one today, can see everything behind now!
Took engine out to fix a few oil leaks and found that case is shot, endfloat is huge! So new case and engine build starting this week.
While engine out in changing the gear link bar bushes, painting everything I can with waxoyl and spruce up the gearbox
Looks amazing. Absolutely love your bus. Did you manage to sort your engine? Mines about to come out for a few jobs doing - half way tempted to find a spare long block and build it up bigger than standard.
