Anyone glued their original laminate back into the interior panels and cabinets?
My Westy interior needs repairing and I'm not sure what glue to use!
hisparkywig said:Cascamite would've been used originally.
Things have moved on a bit in forty odd years Si, some of the products I manufacture are for the petrol chemical industrysparkywig said:Cascamite would've been used originally.
terrier man said:Things have moved on a bit in forty odd years Si, some of the products I manufacture are for the petrol chemical industrysparkywig said:Cascamite would've been used originally.
so have to be explosion proof, :shock: some of the glues & resin, sealants cost a bloody fortune, you can't buy these in B&Q :lol: although E 32 is made by Locktite you would need a 2 piston gun & mixing nozzles for applying. I know of people who have bonded car panels & plastic bumpers & have withstanded impact better than any weld :shock: similar products are used for bonding carbon fibre sections to aircraft frames ie; A380. So if you ever need any.
I wouldn't say I'm a expert Bud just have experience of some quite nasty products resins glass bonders glues & sealants etc, if its in direct contact with the bulkhead I'll get you some E32 but i suspect it isn't as you mention gripfill if it is possible with the resin it has a curing time of a bout 16 hours or over night so would have to be clamped in some way.creationblue said:terrier man said:Things have moved on a bit in forty odd years Si, some of the products I manufacture are for the petrol chemical industrysparkywig said:Cascamite would've been used originally.
So Brett as your the bonding expert (thats bonding ) the panel I made to hold the gas outlet needs bonding to the bulkhead was gonna use gripfill......any advise?
Just
terrier man said:If we would of had this conversation last night I could of got some up to you tomorrow as I quite often use it on the weekends myself problem is work is closed until Monday I would of lent you the gun & nozzles etc; it sounds like its the stuff for you if road dirt is involved, it can be sanded & painted i've filled in cracks in masonary with it still in there 10 years on. :lol:
Do it next weekend.
terrier man said:OK Just won't forget the wheels are in motion. :roll:
creationblue said:terrier man said:OK Just won't forget the wheels are in motion. :roll:
Thanks sorry for the hijack Barkafer
Just
