Htotheunit
Hello!
It's been my first post in AGES but it's time I took some responsibility and restored by bus.
It's not too bad however I will most likely need to replace the rear arch on the underside both the rear sill between the sliding door and the arch as well as the rear section between the arch and the rear corner.
I have the 71 only flared and rolled arches, which panel would require less fiddling should I need to weld it close to the flared section? the 68-71 version or the 72-79 version?
Cheers!
Cheers!
