StuF said:
I doubt there would be much change from £5000 with a decent sized fresh engine, rebuilt gearbox, remote servo and external oil cooling. Never mind the ancillary parts such as carbs/ignition and setup costs.
£5000 I think is more the cost of an off the shelf starter rather than a full built big motor, will demonstrate below:
I'd guess at closer to £10,000 to £12,000 for a 2L plus type 1 motor (4 to 6K Parts), Carbs (1K Inc manifolds and linkage and some set up time), Exhaust (£500 to £1200), Tinware(£300 to £500), Alternator (Bosch £250), Igntion System (£150 to £1000), rebuilt gearbox with equivalent gearing of an 091 6 Rib'd box (£1300),
Then you have the easy to forget parts such as the hoses (Oil, Breather and Fuel) External Oil cooler and filter Set Up, Fuel Pump and Filter, The first time this cost me almost £1000, have just upgraded my cooler and modified the suystem cost me another £300
The most reliable and sensible option for a bus is:
1776cc Engine: (£3000)
https://www.vwheritage.com/shop/211100037/engine-ssp-all-new-1776-no-exchange-needed/?crumbStartPage=1&crumbStartRow=1" onclick="window.open(this.href);return false;
Freway Flyer: (£1300)
https://www.vwheritage.com/shop/AC300002FF/rancho-t2-freeway-flyer-002-gearbox-68-71-1-6-type-eng/" onclick="window.open(this.href);return false;
Carbs: (£400)
https://www.vwheritage.com/shop/AC129K1411/weber-34-ict-carb-kit-t1-2-tp-or-use-ac1297411/" onclick="window.open(this.href);return false;
Exhaust: (£400)
https://www.vwheritage.com/shop/AC251816/vintage-speed-sports-exhaust-system-t2-68-79-std-tail-pipe/?crumbStartPage=1&crumbStartRow=1" onclick="window.open(this.href);return false;
I would try and reuse stock Tinware as they fit best but:
Tinware: (£180)
https://www.vwheritage.com/shop/AC198998/black-tinware-kit-11-pieces-t-p-doghouse-with-air/" onclick="window.open(this.href);return false;
Bosch Alternator Conversion (£270)
https://www.vwheritage.com/shop/AC903900/alternator-conversion-kit-55amp-bosch-inc-belt-pulley/" onclick="window.open(this.href);return false;
External Oil Kit: (£280)
https://www.vwheritage.com/shop/AC117308410/cooler-fan-kit/" onclick="window.open(this.href);return false;
So over £5800 but that is before any club discounts etc have been applied.
I currently have a 2276cc motor on a tall gear'd box and love the torque and HP available but in all honest it isn't much faster than my 1776cc and certainly has been less reliable. Its is more relaxed though having the big motor much less effort as less up and down the gearbox.
Do email me
[email protected] if I can offer any advise or help.
All my best,
Alex
