68only
I can take the following parts to dubfreeze:
Bug swing axle springplates £30 pair
Genuine Domed hub caps set of 4 £40
Genuine US spec split/early bay rear lenses with chrome surrounds £20 pair
Mountney horn push £5
Zinc plated wheel spacers 5x205mm 3mm £18 pair or 10mm £30 pair
3 screw early bay headlamp rim nice £15
Late bay chromed plastic headlamp rims £8 pair
Genuine US spec early bay 1 screw chrome headlamp rims £15 pair
Genuine split bus dome light with OG lens £8
Split westy coat hook £8
Late split rubber cargo door buffers £8 pair
Original split bus popout catch, light pitting £15
split bus cargo handle £8
split bus fish eye indicator lens £5
early beetle inner door handle £5
Split/early bay westy interior light cracked lens £5
Split/early bay westy electrical socket for side of bus £5
VDO black face clock 80mm £10
62-67 RHD bug fuel gauge £10
10 x 12mm press in wheel studs for 14mm hubs/drums £8
Beetle horn bar £8
Late bug gear lever £7
Baby moon hubcaps not bad shape, 1 has small dent for late bay/bug £18 set of 4
Early bug european overriders set of 4 £18
Early bug ash tray for rear of car in chrome £10
Hella reverse light with bracket 50's/60's mint £40
Hella small rectangular fog light chrome back £15
Bosch round fog lamp with painted metal back £15
Hella late 60's large rectangular reverse light £10
Chrome ampere gauge £18
Empi chrome stone guards light rust staining need dipping in coca cola! £20 inc attaching lugs fit bay late bug or Type 3.
American 'truck' rear lights ideal for period trailer £15 pair.
1965 only brand new wiper shaft kit still in packet £10
Period hella chromed plastic under dash aftermarket switch £10
Rubber coated P clips for attaching front number plate to towel rail US style £8 pair.
Early bay standard spindles ideal for fitting porsche discs on late bay or core exchange for drop spindles £40 pair.
Split beam 'Caster' narrowed beam plates £70 per pair
Bay beam 'caster' narrowed beam plates £70 per pair
Split beam into bay bus narrowed beam plates £70 per pair
Split beam urethane bushes for narrowing £80 per set
Straight axle adapter kit with instructions, cable spacers and all hardware £100.
Late bug or bay hubcaps may be genuine set of 4 £15.
55-61 rear beetle 'snowflake' rear glass lens Hella slight chip, but not visible when mounted £20
1961 date stamped 15" solids suit early bug ghia t3 £40 set of 4 no tyres.
Type 4 bay heater electric fan £10
Genuine nearside front 73-79 (also fits '72) front wheel arch £40
Old german first aid kit in metal tin £10
Koni adjustable shocks suit stock to mild drop £25 pair
KYB gas adjust for rear of bus stock to mild drop £25 pair.
Beetle horn bar £8
