Bits I can take to Dubfreeze with pictures
68only
Nov 23, 2006
217
Southsea, Hampshire
I can take the following parts to dubfreeze:
Bug swing axle springplates £30 pair
Genuine Domed hub caps set of 4 £40
Genuine US spec split/early bay rear lenses with chrome surrounds £20 pair
Mountney horn push £5
Zinc plated wheel spacers 5x205mm 3mm £18 pair or 10mm £30 pair
3 screw early bay headlamp rim nice £15
Late bay chromed plastic headlamp rims £8 pair
Genuine US spec early bay 1 screw chrome headlamp rims £15 pair
Genuine split bus dome light with OG lens £8
Split westy coat hook £8
Late split rubber cargo door buffers £8 pair
Original split bus popout catch, light pitting £15
split bus cargo handle £8
split bus fish eye indicator lens £5
early beetle inner door handle £5
Split/early bay westy interior light cracked lens £5
Split/early bay westy electrical socket for side of bus £5
VDO black face clock 80mm £10
62-67 RHD bug fuel gauge £10
10 x 12mm press in wheel studs for 14mm hubs/drums £8
Beetle horn bar £8
Late bug gear lever £7
Baby moon hubcaps not bad shape, 1 has small dent for late bay/bug £18 set of 4
Early bug european overriders set of 4 £18
Early bug ash tray for rear of car in chrome £10
Hella reverse light with bracket 50's/60's mint £40
Hella small rectangular fog light chrome back £15
Bosch round fog lamp with painted metal back £15
Hella late 60's large rectangular reverse light £10
Chrome ampere gauge £18
Empi chrome stone guards light rust staining need dipping in coca cola! £20 inc attaching lugs fit bay late bug or Type 3.
American 'truck' rear lights ideal for period trailer £15 pair.
1965 only brand new wiper shaft kit still in packet £10
Period hella chromed plastic under dash aftermarket switch £10
Rubber coated P clips for attaching front number plate to towel rail US style £8 pair.
Early bay standard spindles ideal for fitting porsche discs on late bay or core exchange for drop spindles £40 pair.
Split beam 'Caster' narrowed beam plates £70 per pair
Bay beam 'caster' narrowed beam plates £70 per pair
Split beam into bay bus narrowed beam plates £70 per pair
Split beam urethane bushes for narrowing £80 per set
Straight axle adapter kit with instructions, cable spacers and all hardware £100.
Late bug or bay hubcaps may be genuine set of 4 £15.
55-61 rear beetle 'snowflake' rear glass lens Hella slight chip, but not visible when mounted £20
1961 date stamped 15" solids suit early bug ghia t3 £40 set of 4 no tyres.
Type 4 bay heater electric fan £10
Genuine nearside front 73-79 (also fits '72) front wheel arch £40
Old german first aid kit in metal tin £10
Koni adjustable shocks suit stock to mild drop £25 pair
KYB gas adjust for rear of bus stock to mild drop £25 pair.
I'll have the original hub caps and vdo clock. 8)
PM me your number and I'll give you a ring.
Alan
If DNA is having the domed hub caps (i think there the ones he wants?) can you let me know what condition the flat vw hub caps are in? or a close pic as i will have em if they are in good nick :wink:
Bits provisionally sold:
US spec rear lenses/surrounds
Popout catch
Empi stone guards
Hella dash switch
Bay heater fan
Bay early spindles
Bay front arch
US spec 1 screw headlamp rims
Koni shocks
KYB shocks
Coat hook
VDO clock
Genuine domed hubcaps.
I will get a better pic up of the flat ones, but to be honest I have loads of em knocking around so will dig out the best set to photograph.
Close up pic of the flat ones
I also have this door, will fit 69 onwards nearside. Needs 2 small repairs underneath pictured, otherwise very solid £40
