Not exactly bud, I just bought a new battery 100 Ah. That should sort it.Good arvo gansters! Just a quick one, who has a bluetooth leisure battery monitor?
Simple one that just wires to the battery so i can see whats going
Whatcha got?!
Cheers dood, but i do see a **** tonne of bliuetooth battery monitors and wondered if anyone has one that works nice and easyNot exactly bud, I just bought a new battery 100 Ah. That should sort it.
Ozziedog,,,,,,,,,,electrics,,,work of the devil for sure
That sounds cool, do you have a link?I wired a USB charger that also displays the voltage. Added a three way switch (bat1, off, bat2) so I can see the voltage.
Good to see the state with engine off and running so you know charging is happing. Cost less that £10 and I can charge stuff off either battery.
BT needed for music
Hope this works. https://www.amazon.co.uk/gp/product/B07L42W4Q9/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 If not search Amazon for Duel USB with LED. It costs more than when I purchased it two years ago! I mounted it in the Glovebox.That sounds cool, do you have a link?
I am, solar when stationary, split whilst on the move and charger at home when neededVery fancy. Are you charging from Solar as well as the alternator?
