joneastwood
BRAND NEW COMPLETE Fuel Injection system never fitted - still sat in the boxes it was delivered in - costs £1800 new.
It has a base map on it for a VW flat 4 2085cc air cooled - type 1 Beetle engine so should be close enough to run up and then let it self-learn.
To fit 48MM IDF inlet manifolds
Spoke to the guys at Emerald and they are VERY helpful.
Kit contents:
Emerald K6
Fuel pump
Jenvey Throttle Bodies and injectors - http://www.emeraldm3d.com/" onclick="window.open(this.href);return false;
K3 ECU, software, maps, PC serial comms lead, operator’s manual
Jenvey Pair of Twin 48mm Throttle bodies IDF downdraft TFP48i
Jenvey Air horns 45mm x 40mm - set 4
Jenvey Fuel rail kit
Jenvey Throttle linkage kit
Jenvey Throttle linkage mounting bracket, single/over
Flying loom on ECU plug with open ends for sensors
Set x4 320cc/min injectors - good for up to 205bhp @80% duration
Injector plugs x4
Adjustable Fuel Pressure Regulator + bracket AIR004
Throttle Potentiometer & plug
Air Temp Sensor + plug
Water/Oil Temp Sensor + plug
All Wiring
Complete instructions
All you need to complete the kit is to fit a return to the fuel tank as well as a Fuel SwirlPot/Surge Tank and your good to go.
I also found out that the ECU can do traction control if you buy and fit a sensor and a sprocket ring to the drive shaft :lol: :lol:
Located in Swindon M4 Jnc 15
£1500
£1500
Kit contents:
Emerald K6
Fuel pump
Injector plugs x4
All Wiring
£1500
£1500
