Bump stops.
j.nathan
Nov 18, 2006
212
North Lincs.
Just fitted CB performance adjusters to my front beam to drop her about 4".
Removed the bump stops too.
Is it okay to run without bumpstops?
I can fabricate some adjustable stops but are they necessary?
Is their original purpose to protect the ball joints?
I'm pretty sure that's a secondary reason - if you didn't have any bumpstops and your suspension failed your tyre would end up against the top of your inner wheel arch - this could cause a wheel (or both) to lock up, your bus would dive violently and you'd be in a lot of trouble!
If you can I'd recommend a replacement!
you can get adjustable bumpstops from red 9 design.
its a good idea to run them if you can..
