chippi said:Hi and welcome to earlybay!,
The mods will prob stick this in technical bud as you will have better response, theres loads of threads in search option to browse through however most peeps tend to use the bubble foil stuff from b@q and the like and 25mm celotex slabs, i wont use fibre wool as its absorbent.
hope that helps.
chippi said:Its the Condensation , buses and heavy breathing after a night on the show beer equals a damp mix.
Ozziedog wrote:
Don`t confuse condendsation with induced vapour
dubscum said:if you drink enough you can leave your sliding door open with no heating in - condition and sleep quite comfortably on top of your sleeping bag. this theory was tested in Folkstone before Ninove last year. having a frost on you when you wake up was new experience. I think :? there was no "interment heating" as it was 3 blokes :shock: :msn4:
I used some really expensive rubber stuff that you peeled the back off, took every panel cover off and stuck it everywhere, when i went camping with the wife and kids (therefore no hanky panky and all door closed :lol: ) I still had no heater / heating and all the insulation made no difference, it was just as cold. So does it really work ?
sparkywig said:dubscum said:if you drink enough you can leave your sliding door open with no heating in - condition and sleep quite comfortably on top of your sleeping bag. this theory was tested in Folkstone before Ninove last year. having a frost on you when you wake up was new experience. I think :? there was no "interment heating" as it was 3 blokes :shock: :msn4:
Not really, you still got single panes of glass that cover a third of the surface area of the bus (and I've got a 6' x 3'6" hole in the roof as well). The only difference I've found after stuffing my bus' cavities with celotex, and carrying out vigorous research camping all year round for the past 2 1/2 years is that I don't have to turn the sounds up as loud when driving.....
ozziedog said:Also you do need some ventilation because of the sweaty oiks syndrome :shock:
Ozziedog,,,,,,,,,,, Only got none cause I ain`t got to that part of the list yet :mrgreen:
