That is what i suspected, i will try a late bay cable as they are approx 50mm shorter so should make up the difference (cant find anyone that lists a LHD one)
Rhd is longer than lhd, the cable has to travel not only from front to back of the bus but from 1 side to the other because the clutch lever is on the left side of the gearbox casing. The same applys to throttle cables, had to order 3 different cables before i got the correct 1 :roll:
