Wishart
Help!
Ok, quick summary: Thought my clutch cable had snapped as feeling/resistance had gone from the pedal. It hadnt. Pedal hits floor but springs back up - so ended up pulling engine and finding this...
Release bearing was definatley worn, and was not 'clipped' onto release arm, no apparent damage to rest of clutch. We pulled this bit of worn/mangled metal from the teethed bits on the pressure plate!
Not sure where it came from??
SO, in my haste, I bought this style of release bearing from GSF (only one of two kinds) and it suits the release arm but didnt sit snug when the clips were put on. Very loose in fact.
So we trimmed the clips a bit and tightened them so they held it tighter. That was it, and we put the engine back in. Pedal freeplay was still excessive but it was 'biting' at the bottom so tightened the wingnut right up but no change.
Next day, fired the engine up, selected first and drove happily off the driveway. Put it in reverse with no problem and put it back on drive. Pedal freeplay is now normal (seemed to do it by itself!!!!!!) Push the pedal down a few times and get a kind of click feel at the bottom and sure enough it goes "pop". Back to square 1!!!!!!! No feeling in pedal cant select gears :evil: Definately felt like the release bearing had slipped or something.
What can i do? Between me and Bobley, we reckon that we need to upgrade all the components so that they work with this newer release bearing? The clutch kits dont seem to have ALL the bits so are they worth it? Im baffled and im tired of it :| Gonna try to drop the engine AGAIN this weekend if we can be sure of how we're going to fix it.
