dubdubz said:
could you rather than clearance - go with a steel 'end' say 3ft into the garage space and remove the fatter wooden section? you can get side slides and 2 springs - guessing you have 1?
WOW :shock: :shock: :shock:
Have you done a course recently in mind reading???
I have the original Garador side slides and springs if that’s what you mean as that’s where most of the mechanisms are . The big issue that’s causing all the wear and tear on my back at the moment is the fact that I can’t attach the side springs until I can lift the door fully. I also can’t see a clever way to work out exactly how much to take off without manually lifting :shock: straining :shock: to get it up a bit then put a block of wood under it until the top touches and mark it with me little pencil then let it down again, then lift again, and a bigger block of wood and a wedge etc etc etc. Now I’m a little further and I’m using ‘’’ builders only’’’ measurements
, now my exact measurement at the moment is two Whitbread crates and a piece of four by two on the flat , an off cut of architrave and a tad of a wedge
but in the larger scheme of things I think I’m about half way in the relieving side of things :roll:
When I’ve got the damned thing working I’ll take a good restock of the situation and look at it with fresh eyes. At present I’m thinking to add two further purlins to aid and assist the butchered one, I’ll see what space I have left, at the moment I’m thinking a four by two on it’s flat just down a tad or wherever I can slot it in downslope and upslope maybe a four by two the right way up, I’ll see what we can fit. Also I’ve mentioned that I’ve been reusing any old crap laying around / recycling and I’ll see if I can cut a couple of sections of this steel roofing sheet and fit to both sides of my massaged purlin using multiple strategic fixings or any old screws I haven’t found a use for in the last twenty or thirty years and that should just about sort it. Then I’ve gotta add to the bottom of this door, again I’ve put off thinking about this in depth, and I’m thinking how I can frame up and use more plasti coated steel sheet. It’s a very similar profile to the existing garage door if I turn it the opposite way to where I’ve used it above to cover my laddery plyish steeled up lintel , I’ve got various ally remnants for the frame, including various old ladders so I’ll try and make it as light as poss because this will be more work for those poor old springs that must be forty years old, however both pairs seem to be in remarkably good shape(so far) :mrgreen: So I’ve gotta day off tomorrow and the lecky plane comes out to play again, thankfully I’ve got a shavings bag on it too :mrgreen:
Ozziedog,,,,,,,,,,, I’ll pop up some pics, don’t look at the woodworm :shock: :shock: :shock:
