cunning plan
- Joined
- Jul 15, 2008
- Messages
- 2,625
- Reaction score
- 1
- Location
- Northamptonshire
- Year of Your Van(s)
- 1968
- Van Type
- Clipper / Microbus
Edit:
Here is what I hope to build...
Edit:
Disregard disks brakes in this post from a Crossover, I won't be using them. Vented conversion kit planned..
Edit:
_____________
Right, may as well make a proper project thread..
To bring you up to date, I bought this 1968 bus 'Clipper' with a home-made camping interior as a toy after selling my wedge a while ago and you NEED a toy...
It needs alot of panel work but the rest is pretty solid and it was at a reasonable price for the age. The plan was to run it as it was for the summer then decide if I wanted to keep it....
I ran it for a few days but noticed the ride was total sh!t, to the point that the smallest bump in the road would have you bounced out of the seat!! I asked you guys if all lowered buses ride that badly and was asked to post some pictures of the beam to try to work out what the PO had done to the bus.. http://forum.earlybay.com/viewtopic.php?f=4&t=8336" onclick="window.open(this.href);return false;
It was decided that the bus had been bodged which was the reason for the poor ride and a weedeater beam was needed and new shocks, bascially a new set up..
So I thought while I was at it, I would swap the dodgy drum breaks out for some discs from a '71 bay that I bought from an EB member 'JP' - Nice guy, held on to them for me for a few weeks then met me on the way back from a holiday in Cornwall..
While all this was going on an oil leak needed to be fixed which wasnt a major issue, it was the oil-pump gasket..
So I repaired that.. Cool. But no, then the van kept stalling when warm.. Asked about it here again and a carb re-build was needed to eliminate it from the potential issues.. I bought a £10 rebuild kit from GSF (who I have to say delivered for free and next day - impressed) and rebuilt and cleaned the whole carb..
So, I put the carb back on then relised that all the settings would be out so I bought (I know, yeah, MORE money) a Bentley manual from Cool Air, which again, is pretty good, much better than haynes for explaining things..
Carb back on and tuned like 3 times..
Still cant get the thing to idle when hot. It starts on the key when cold and chugs away nicley, about 1 minute when the choke starts opening it starts to splutter, then it will stall unless you blip the throttle..
I figured that I elimated the carb from the equation, it must be an air leak somewhere meaning the engine is fine when its compensated with the choke but as that opens it doesnt have the compression?? < Im guessing here...
Any ideas?
Edit:
Edit:
_____________
Any ideas?
