Hi all,
We've found a crack on the cylinder head (Cylinders 3 & 4) between the spark plug and valve apertures. It seems to propagate through the spark plug thread and to the surface. Been advised this is more likely in need of replacement than repair.
Any advice on where's best to buy from, or has anyone managed to get something similar repaired? Also would it be best to replace both cylinder heads as a pair?
Will add pictures later when not on mobile.
Thanks in advance,
Katie
Thanks in advance,
Katie
