Having measured 6 times and taken the plunge and drilled the holes in the beltline i fitted the delux trim which looks pretty damn cool. My problem is now i've got to the corners and can't make it fit properly :roll:
I have put the holes in at the same line of the others but the trim doesn't want to lay flat unless it's on the piss and not in the centre clip. I tried numerous times last night and eventually got it to sit straight and in line withthe other trim but this leaves a gap behind the centre of the curve which you can see down into To be honest the trims are pretty bendy but still won't bend to the curve as if you try to bend it in one way the end pings off the clips.
They are the C&C german ones if that helps. Any suggestions anyone please :?
