I have picked up the shafts , spacers and the cable end plates today , endplates need plating and the shafts need the holes to fit the roll pin in , then they will be up for sale on the site . Graham from Midland Earlybay has fitted a couple and has given me a few tips to fitting it . Not as straight forward to fit as you would think , but will fit . Involves fitting the shaft first with no endplate fitted then assembling it all in place . We are getting there , this will cover all 1969 to 1972 models , i would sort the 67 to 69 models but unless someone can let me have the shaft and endplate from there bus to copy im a bit stuck . Can even be a broken one , would be nice to have the wheelarch end fittings as well . Then i can sort the bearing plate repair section out . Obviously you would get a shiney new one to replace the one you loan or give me .
