trebor said:There should be a taper tap which you can lubricate with gas grease, Rocol gas grease from RS components is good stuff. Gas cock grease is thicker, giving you a stiffer tap action. Don't put too much on or you will block the low flame holes if you have any. Always check for leaks !!! If the taper is scored chuck it, if you can't get a new tap chuck the cooker.
RICH-I-AM said:Would it not be safer to find a specialist who could give the stove a full refurb?
Rich
