Disc brake master cylinder
EgoTrippin
Apr 8, 2007
1,355
Brighton
Just about to fit a new disc brake master cylinder as I've just upgraded to CSP front discs.
Question is, the drum brake master cylinder I have just removed has 2 electrical connections, whereas the new disc brake one only has one electrical connection?
Which electric conection do I hook back up to the new master cylinder?
Steve
My bus only has 1 connection plugged in on my master cylinder too :? i 'think' it's the rear connection and the lights work fine.
As long as your brake lights work it isn't an issue. When I changed my MC I coun't get the Dash warning light to work properly so I took the bulb out.
Very much trial and error. I was on my own when I did it so I had a 12v tester in the cab conected to a long wire which I ran to the wires underneath. When the light came on with a push of the brake pedal I knew I had the right one.....
I know I'm a but simple really :mrgreen: :oops:
