vwjim said:Yep, had one of those remote servo's fitted to the bus for years now, and I've been selling them for £268 plus the £10 P&P since then. They're great. DOUBLE your braking power. They work with 4xdrums or 2xdisk+2xdrums or 4xdisks no problem.
The CE direct servo's bolt straight on to LHD buses, but the pushrod needs to be re-worked / modifed to make it work on a RHD.
Joval said:vwjim said:Yep, had one of those remote servo's fitted to the bus for years now, and I've been selling them for £268 plus the £10 P&P since then. They're great. DOUBLE your braking power. They work with 4xdrums or 2xdisk+2xdrums or 4xdisks no problem.
Cheers, how are they plumbed in? Where do you put them?
bobley said:The servo did foul "my" clutch cable but that is entirely because I have made my own clutch cable and I had it routed between the beam tubes. I've now moved it up to the original split bus position and it looks fine..
slammedresto said:vwjim said:Yep, had one of those remote servo's fitted to the bus for years now, and I've been selling them for £268 plus the £10 P&P since then. They're great. DOUBLE your braking power. They work with 4xdrums or 2xdisk+2xdrums or 4xdisks no problem.
def interested in doing this in the near future, is there earlybay.com discount if we order from you
whats the ins and outs to fitting one of these then, what else is needed
