Harlequin said:If you go alternator you have to change the stand & posibly the fuel pump because of the larger diameter of the motor
robins said:do i go dynamo or alternator to replace the shagged one :?:
robins said:ps
it was referbed,only done about 100 miles with it,
steve92 said:is it beyond repair then? i went alternator last year.got a kit from vw heritage. was a bit of a pain in the arse, but got there in the end.as already said, looks like you will need to change the fuel pump for clearance. i also had to make a carb spacer to lift the carb up to clear the alternator. get some more pics of the damage up. is the shaft chewed up, and does the shaft turn ok?
Araon said:As I understood it it was the ally case that was damaged?
if so then pull the armature out thoroughly clean the whole beast and get rid of any possible trace of metal swarf/powder and reassemble, confirm the fit of pulley to dynamo and away you go....
VWAIRCOOLED said:robins said:ps
If it was refurbed,usually they will repair it under warranty or good will,especially as you've only done 100 miles?
