Marvel
I definitely think this is what I need, the RHD kit. Are they ready to go?
butty said:That looks spot on , springs not over stretched at rest . As to cable i think cables seem to vary a bit length wise between makers , some do the length from the centre of the eyelet and some do it from complete length from end to end .
I expect it would be the same on all stock carbs .
Is your pedal going all the way down now ? and opening carb up fully ? Does your pedal have the extended lip on the top that acts as a pedal stop ?
I have the long rods with the swivel/rose joints fitted and loads of lhd mounts , but as ive said before i havent yet seen 2 rhd buses with the mount in the same place , the one on slow-lane-matts looks like a lhd swivel mount with the rod would do the trick on his . But if you can post me pictures of your under side we can go from there .Marvel said:I definitely think this is what I need, the RHD kit. Are they ready to go?
butty said:So if you lay pedal down on the floor then open up carb im guessing cables too short ? Pedal angle looks high aswell . I fit a short pedal rod on these i wonder if i have given you a pedal rod from a split bus kit , they are a longer shaft . If possible bung me a photo of the pedal shaft out of the bus . Its the only thing i can think of at the mo . [email protected]
MrAndyP said:Turns out i am missing the pedal stop for a start.....
butty said:I think you will find they all are lol .
67westy said:MrAndyP said:Turns out i am missing the pedal stop for a start.....
I don't have a pedal stop and mine goes to the floor for fully opened. are you running a solex and alternator? if so are you sure its fully opened and not just caught on the alternator casing? I had to file a chunk off mine
Maybe i should make them aswell , but then all the pushrods would be too short .arrrrrrhhhhh .... :roll:MrAndyP said:butty said:I think you will find they all are lol .
Ive found this after looking at various pictures of peoples cab floors. and the fact im struggling to find one for sale in the UK. :lol:
butty said:I have the long rods with the swivel/rose joints fitted and loads of lhd mounts , but as ive said before i havent yet seen 2 rhd buses with the mount in the same place , the one on slow-lane-matts looks like a lhd swivel mount with the rod would do the trick on his . But if you can post me pictures of your under side we can go from there .Marvel said:I definitely think this is what I need, the RHD kit. Are they ready to go?
Easier here http://www.buttysbits.com" onclick="window.open(this.href);return false;Slammed said:Hey, I'd like one of your kits for my LHD '68 single cab please. Is the paypal the @live address? Do you need any more details?
Looked at piccys and i think a flat mount wouldnt work , leave it with me i will see if i can sort something out ...........Marvel said:butty said:I have the long rods with the swivel/rose joints fitted and loads of lhd mounts , but as ive said before i havent yet seen 2 rhd buses with the mount in the same place , the one on slow-lane-matts looks like a lhd swivel mount with the rod would do the trick on his . But if you can post me pictures of your under side we can go from there .Marvel said:I definitely think this is what I need, the RHD kit. Are they ready to go?
You have PM and piccys
butty said:Looked at piccys and i think a flat mount wouldnt work , leave it with me i will see if i can sort something out ...........
I did and pm just sent back . cheers . Yours is so different to marvels setup .68_early_bay said:Hi butty, did you get my pm and pics![]()
