jimme1971
Thanks for quick reply Simon, No worries, you are but one man and you're doing a great job!
67westy said:butty said:Im pretty sure it will fit . But as with everything I sell if it doesn't work for you bung it back for a full refund .67westy said:I'm really interested in one of these. Can I just check that it will definitely fit an early 68MY? I bought a few bits a while back to replace worn parts but I seem to remember that the linkage I had was pretty different to what was on the VWHeritage site diagrams so the parts didn't fit :roll:
I guess I need to crawl under the bus at some point and have a look![]()
Top man, that's the kind of service I likeI'll put in an order now although I probably wont be fitting for a couple of months. Hope that is still ok!
baz1875 said:I fitted mine yesterday very simple and has made an instant difference cheers butty
butty said:I think spring should be hooked up a bit higher so its not as stretched as in the picture , the ones ive done I just go straight back about where the lipped part is on the body . Just dont want to over stretch it . I will be doing another bus soon and will try and give you guys some more photos etc .
creationblue said:butty said:I think spring should be hooked up a bit higher so its not as stretched as in the picture , the ones ive done I just go straight back about where the lipped part is on the body . Just dont want to over stretch it . I will be doing another bus soon and will try and give you guys some more photos etc .
Strange cause that's where I fitted it :? Ill have another look
That looks spot on , springs not over stretched at rest . As to cable i think cables seem to vary a bit length wise between makers , some do the length from the centre of the eyelet and some do it from complete length from end to end .MrAndyP said:Fitted mine today.....SO easy.....
I also fitted a new throttle cable at the same time,but now my pedal only goes down half way ,the lever on the carb is fully open. the cable only just reaches where it bolts up at the carb,5mm shorter and it wouldnt reach.
Does this sound right? is my cable too short? i bought the cable for a lhd 68-71 which my bus is. could my carb be off a later or earlier bus?
Im confused. :-/
