"Just like its vehicular counterpart you can stand up inside "
Ermm dunno about you but I can't stand up in a split, well depends how much of the floor is still intact, I can do it if I put my legs either side of an outrigger.
"What’s more its fabric roof and sides are 3000mm and 1000mm respectively – mighty impressive, especially when you consider British Military spec is only 800mm (and we consider things like that quite a lot). "
Probably more waterproof than most splits too.
"Factor in two zip-separated double-size rooms, allowing couples to sleep/knit yoghurt/spread the love in private, plus an outer that can be put up first to offer some shelter as you erect the other bits and bobs, and you’re looking at the greatest thing to hit the world of boho living since… well, since the original VW Camper Van."
Dunno about you but its fairly obvious when someone inside a tent is on the job, so if your sharing the same tent and seperated by a piece of cloth I still think its going to be fairly obvious if someone in there is getting their back doors bashed in. Furthermore if someone describes my lifestyle as "boho living" I'd top myself.
