slow-lane-Matt
I bought one of the £16 ones on the recommendation of another post, but am having problems.
It all fits together fine, holds correct (20PSI) from tyre etc.
When I release the nipples in the correct order the fluid comes out without bubbles from each corner.
...but the brakes are still way too spongy.
Have successfully bled brakes in the past with wife pumping the peddle.
..and I have read the Eezibleed instructions.
The instructions talk about "ensuring the cyclinder is in the closed position" on some cars - is this the case
for VWs...? Could there be trapped air in the cylinder?
The instructions also talk about pumping the peddle in some cases, which kinda undermines the one person thing...
I only replaced one slave cyclinder so most of the system should be intact and air free...
What am I doing wrong...?
