Electric fuel pump and blank?
vw_mad
Sep 14, 2010
308
Hi
Looking for information about what type if electric fuel pump to use on my engine as I believe this will fill the twin carbs better than the original pump and then where I can get a blank to go over the old hole where the existing pump is fitted.
Thanks .
For the 40's the Huco rotary pump is very good, 2.5psi output and shuts off when up to pressure,very quiet operation. It is a suck pump so needs to be placed in the engine bay. Also advise fitting a durite fuel solenoid near the tank to stop flow.
Just done both to mine do can send you some photos and buying advice..
