Electric fuel pump questions
mr scoops
May 8, 2010
1,144
I'm going to remove the stock mechanical fuel pump on the 1641 that's going in the 71 and replace it with a Huco electric pump.
The question is should I have it running via a dash mounted switch and do I also need to install a g-force activated switch so the pump is disabled if I have an accident?
I believe mine takes its live from the oil pressure switch, which means it only runs when the engine is turning over. I do have an extra manual switch for rare occasions if I haven't run it in a while and the floats are empty
Looks like I feed from the alternator actually, but same principle about engine turning
I wired mine the same as Gvee. Feed from oil pressure switch. I just move the terminal connection between 87 and 87a if I have had it standing for a while (dry float chambers) but yes you can fit a primer switch in place instead.
Having said all that I do have a g-force switch laying around and have considered this for neatness/simpler wiring but then you lose protection if you lose oil pressure... It's all a bit of a toss up.
So, I'm not the greatest fan of this 'ere new fangled elastic-trickery.
Can someone knock me up a wiring diagram so I can get inwardly digest what I need to buy and how I need to set it up.
Just a query, why opt for an electric pump? My 1641 with 36Dells and a fuel pressure regulator works well. What improvement would a leccy pump make?
Being battery driven there is less drag on the engine. In the same way as using an electric fan on a water cooled vehicle, it is only active when needed (i.e. the occasional pump to top up the float chambers). So instead of a constant drag on the engine with 90% of the pumps being bled away through the relief system you have an electric pump that only occasionally ticks up a bit more fuel.
And we all know that these types of mods are worth another 10bhp... :lol:
I've got some worry gauges to fit, one of which has a sender in a fuel pump block off.
Wire the inertia cutoff in series with the pump an consider fitting a fuel cutoff solenoid to be on the safe side (mount it by the tank outlet). My inertia switch was from a Rover and obtained from eBay with the pig tail for £10. You will need to mount it vertical to a solid chassis rail somewhere.
