I’m fitting a HUCO low pressure fuel pump to my ’69 Westy. For safety I’m going to fit a relay (Halford’s item 184161 HEF 557 12V 30A 5 pin) in the system. I’ve found this wiring diagram in the archives here.
What I need help with please, is: 1. I’m running a dynamo not an alternator - is this still OK? 2. If yes, can I connect the “To Alternator warning light” to the blue wire at terminal 61 on the Voltage regulator, and; 3. Can I connect “+12V from Ignition fed fuse” to the black wire at terminal 15 on the coil?
Thanks for your help, much appreciated.
