Electric fuel pump relay diagram
gagvanman
Oct 24, 2011
535
102
Grantham
I am thinking about installing an electric fuel pump (huco-low-pressure-12v-fuel-pump-133010). I realise that I need a relay to control the power to the pump. Does anyone have a diagram (and part numbers) to show how to do this including the function of cutting power to the pump if the engine stops but the ignition switch is still on?
Thanks...
https://www.dellorto.co.uk/shop/vw-carburettor-kits-parts/vw-aircooled-manifolds-linkages-parts/other-parts-vw-aircooled-manifolds-linkages-parts/csp11-electric-fuel-pump-safety-cut-relay/
Sent from my SM-G975F using Tapatalk
Or better still
https://m.vwaircooledworks.co.uk/Fuel-Tank-Cut-Off-Solenoid.html
Excellent service from Peter
Doesn't work as well as a solenoid which cuts of the fuel just below the fuel tank and can be used as a kill switch to avoid theft as well as linked to Peter's clean extinguisher
