Hilly_70
Guys
Just been doing a bit on the bus today...
my engine is a AD code with an adaptor plate config at the back.
As you can see there is only 2 bolts holding it the the support bar ..
Now to be honest its been like that since I had it ... (10 years! .. yeah I know!)
My question is should there be a bolt in there? .. if you look down the hole, there are no threads, no hole and it doesnt look like it has sheared off in there .. Im pretty sure the casing isn't tapped there .. The other 2 bolts go through the adaptor plate.
So whats my options and does it need a third bolt..
Hilly
Hilly
