Don't know if this is in the right section??
I have recently bought a new(recon case)16tp engine or lead to believe.
The case has the mounts for the van and not the adaptor needed for a beetle engine.
So am i right in saying i have a bus engine case??
My next question is what size were bus engines?? 1200/1300/1500/1600/1700?????
The reason i am asking is i am in the process of running it in and have done about 130 miles so far.
I have not thrashed it and am careful to change up or down so as not to labour the engine but find any sort of rise/hill and the engine slows quite quickly but i do not bury my foot in the floor.When van loaded with the family etc it seems under powered.
I change up into 4th at 30 mph on the open road and then wind it up to 50mph.
When i am on me own it seems ok but have yet to FLOOR IT and see what top speed is.
Now looking at posts ref MPG etc all you guys seem to be hitting 55-65mph loaded.
My code on the block reads AB 782283 and looking on varies sites AB is a 1300 block??
Have i been sucker punched or can you put 16tp heads on 1300 case(has points for mooooostache bar)
Am running a 34 pict 3 stock oil bath and exhaust.
Will engine be freer after time or is it a 1300tp and will i kill it in a bus?
All bits i have on it are for 16tp.
Anyway of telling if it is a 1600 without taking heads off??
Any help/info welcomed.
