Molmeister
- Joined
- Sep 7, 2011
- Messages
- 11
- Reaction score
- 0
Evening All ...
Many thanks for pointers to date
Engine removal is next on the winter list following cylinder compression "issue". I'm sure this (engine removal), has been referenced a hundred and one times on this forum but I've used the search facility and not really come up with much - which I assume is me not using the search facility corrrectly.
So - please point me to the right URL - as a "greenhorn" to this site please excuse my indulgence in asking :mrgreen: OR
Give me some pointers on how to remove an engine from a 72 Cross over - so the engines coming out the bottom. I am sort of, aware of what needs to be done and in what order...manuals to the ready - what I don't know is how to physically lift the Bus "so" high.
So - How high do I need to raise the Bus to get a stock engine out
Is there a tried 'n tested method to raise a Bus without using a garage or their lifting gear (ie I'm doing this at home with a jack/ramp/bottle jack I presume
Where's the "best" place to raise a Bus ie Underneath (as opposed to "inside where it's warm!")
Should I buy an engine stand to work on the Bus once out - my mate said he'd go halves as he's going to have a crack on his Beetle and will use it - Good buy??
Should I be buying a Workshop Manual - does it tell me anything about this type of info...
Any help would be appreciated - not in the engine removal itself but in prepping for it as such......
Cheers Folks
Cheers Folks
