Kris
Active member
HI
Iv just finnished rebuilding my 1600 twin port stock engine after the big end bearings disinteated on my way home from Cornwall. My problem noe is that my rebuilt engine will not fire into life and shows no signs of doing so.
I think my problem may be fuel related as i have a good spark on all of the plugs, which are new and have replaced the distributer and coil. the timing has been checked and rechecked and is set correctly. however there don't appear to much, if any fuel finding its way to the spark plugs, although there is fuel from the pump to the carb. the carb was working fine before the rebuild, and no changes were made to the settings, although that has since changed, but to no avail.
I have been wondering if there could be a problem with the manifold? it does'nt have any visible damage, holes or blockages though. The manifold that i am currently using is a different one to that i was using originally as i found one of the ends, which attache to the exhaust was blocked.
I would be grateful for any advise on what the problem could be!!!
many thanks
many thanks
