wonderbus70
- Joined
- Mar 14, 2013
- Messages
- 18
- Reaction score
- 0
I have a 1970 van with standard 1600 engine. It is a twinport engine with bocar carb and pancake oil bath filter. The engine is recon and has done about 10000 miles. The van was running well but started to play up refusing to start for the missus then eventually stopped altogether. It was turning over well but not making any effort to start.
I checked the points(all fine), plugs (getting a sparK) pump (working) but it was not making any attempt at starting just turning over. Thought problem with carb but not sure. was about to give up and call aa to tow me home and poured left over petrol into carb. The engine then started when my 10 year old daughter had a go!!
The engine ran fine for the 100 mile journey home apart from the manifold which iced up under the carb. It has never done this before! The manold under the carb was white. As I was worried about stopping the engine as battery was nearly flat I set off. After about 30 miles I stopped for fuel and it seemed to have sorted itself out. Manifold was cold but no ice.
The engine ran fine for a day or so then started sounding a bit rough. Now it won't start again. Tried changing the carb for old one I had but still nothing. Any ideas what to do next? Have a replacement coil that I have not fitted yet?
I have sprayed the carb with carb cleaner but can't see anything wrong with it.
