Now I've "fixed" my self locking sliding door issue with a piece of blue tack I find that shutting it from the inside is a bit scary. I have to literally heave it as hard as I can which must put some large forces on the mechanisms. If however I shut it from the outside I just give the back edge I little push so it catches then the handle can bring it in.
So is it possible to attach a handle or strap to the bolts in the recess at the back of the door so I can pull the back in from the inside? It almost seems like it should have been something fitted as standard. I remember my late bay being the same.
