VW Aircooled Works said:Hi, a picture of one in a stock early bay engine bay that we have to install later. The system is very compact being only 24cm long and diameter 10 cm or so. As such it is very deceptive, but as you can see from the picture it fits without even being noticeable from the outside. At shows I have to place a mirror on the rear deck so people actually see it is there. I have installed several in std, twin carb and modified set ups and no problems, as you can see from the picture the system sits before the centre cross member so well back from the carb, dynamo or fan housing. Footprint for the brackets is 10cm by 10cm only.
The system has been designed to be compact by the quality of the engineering meaning it can be primed to a much higher pressure than an off the shelf extinguisher. It is a pity we can have touch and feel app to be able to show that this is a serious piece of kit.
The next show I am trading at is Stanford Hall, Lutterworth 5th May so it can be seen installed and we have products on display
image of the system installed. Simple wiring of positive off the coil and negative from ground to pressure head. All cable to run to dash supplied. This is a robust system and engineered to precision standard, carries 3 year warranty and 10 life expectancy.
thanks
