Pcb GreenBay
- Joined
- Sep 21, 2008
- Messages
- 45
- Reaction score
- 0
I decided to keep my custom Mag rims on the porsche bus so this set i was putting together to switch to Porsche Fuchs 6" front and 7" rears are now up for sale.
The following is what i have up for sale:
Rear:
Shortened axels, by aprox 18mm to fit fuchs wheels without the axel sticking out of the center,
5x112 rear hubs changed/maschined into 5x130 and also shortened 18mm on the outside to fit the axel again.
All you need is backing plates, drum drilled to 130 and pads but anyone with a good set on theirs have whats needed soo.
On some busses a 3mm spacer ring is needed on the inner side of the axel to prevent the brake drum rubbing against the backing plate.
Front:
Porsche 944 front hubs , and a set of calibers (needs a rep kit) , a set of early 911/912 discs ..
All that is needed is to make a mounting bracket for the calibers and you're off to go.
A spacer ring , i'll post the correct width, is needed on each spindle and the porsche hub fits your bay spindle.
2 x 6" x 15" early look fuchs repro
2 x 7" x 15 early look fuchs repro..... no center caps...
I'll do the rest of the polishing on the rear wheels.
The front ones are polished prof out at a shop. Price for this was 240pounds.
As you can see from the pictures the rear ones arent bad so i can use a good loooong evening and paint the centers.
Price for mechanics in this setup is UK pounds 600,- or best offer.
Price for Early style Fuchs 6" + 7" (x15") is UK pounds 600,- or best offer
I have parted the prices up due to fact i'm located in Copenhagen , Denmark and knowing thet freight prices
from uk to denmark and vice versa it might be a little tricky tp ship the wheels.
However i can offer the entire package for 1000,- uk pounds.
I'll have to work on a shipping price..
Contact :
Peter Brauner
+45 27204020
Here or on [email protected]
Pictures will follow and some are in my bay bus thread.
Merry christmas everybody
Rear:
Front:
Contact :
Peter Brauner
+45 27204020
