Front calipers shot, pistons stuck, scored, corroded the lot. Has any one used the conversion kit from JK to fit later calipers on an early bay? Any tips?
Yeh i have fitted them as well no probs although the bolts supplied were to long so had to use the old ones
my old calipers were pretty much the same condition as yours :roll:
Hi
If you decide to go down this route,I have a set of spacers/bolts that I bought for mine but managed to find a pair of Calipers so didn't use them.£12.00 posted ....Dave
The bolts would only go in so far and then there would be something stopping them from going right down almost like they have to be the exact length of the thread :?
Did mine last year and had clearance problems on the hub. My yank import had Jap discs/hubs and the calipers fouled on the cast in makers marks.
Ground the markings away and still fouled. Spoke to JK and was told than sometimes grinding the caliper body is necessary. Very carefully took off as little as I could get away with. Clearance is less than 1mm but a year on, no problems.
