bottom rung
So, I have the front panel prepared. Holes in the windscreen flange ready for spot welding, holes in the sides and top of the grill apurture as well. The panel sits hard against the flap assembly thingy and sits nicely against the windscreen pillars. It even fits nicely on the lower a-post. The problem is the area around the bulge. I can get it to fit on one side, allowing a bit to fold over into the door shut, but the other side has no spare metal to fold. I can shuffle the panel across and still get a reasonable fit, but thal leaves me only a couple of mill left to fold over, with plenty of pre-crimped flange showing outside the doorshut.
I have been using ratchet straps and plenty of clamps, but there is no way this panel is going to fit as far as I can see. It could do with being about a centimetre wider at the mid point.
I figure my best option is to fit one side properly, and cut the panel top to bottom about an inch in from the fold on the other side, fit the folded part and fill the gap. It seems a bit drastic to have to do this on a new panel. I can't return the panel as I have already fitted indicator blanking plates and removed the badge bulge.
Anyone had to go through this as well?
